R
R4BOE
hi
what code do you think should be atributed to a 2 core SWA cable used as part of a Main bonding conductor the steel Csa equivelent required is 64mm sq and the current 2 core 25mm sq swa is a BS 6346 with a steel csa of 60mm sq
the above info on the required CSA is from the ESC technial manual
the installatrion is mid - late 1980's TNS copper equivelent required is 10mm sq
