Discuss What Type of plug Socket? in the DIY Electrical Advice area at ElectriciansForums.net
Rowls1967
Hi,
I've just moved into a property in the UK, only to find this non-standard plug socket.
I was wondering if someone would advise me of what type of socket this is, also if there's an adaptor to convert it to the usual UK socket type?
TIA for any advice.
Richard
[automerge]1599210478[/automerge]
Hi,
TIA for any advice.
Richard
I have now identified that it's an MK non standard socket, although I cannot find a converter plug that will allow standard UK plug to be used.
Is that actually within your property. It has a non standard earth pin and is normally used to prevent normal usage or unauthorised use.
Definitely your hallway and not a communal area as they are often put in to stop tenants using them.
Reply to What Type of plug Socket? in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
Hi, just hoping for a bit of advice. When I travel abroad (Europe, predominantly Spain/Cyprus) I usually take a single travel adaptor and a UK 4...
Hi I am attempting some DIY I had the wire installed as I was going to have an electric cooker. This changed and I now just want to put a...
Hello, I'm seeking some advice on an overheating plug adaptor please. Complete amateur so please forgive any errors in calcs / assumptions /...
Hello My dear old mother tried to clean the tiles in our utility room by using a damp rag and I think some water may have dripped into our plug...
4K
