Hi guys I'm needing new extension lead to power light and music centre and have plenty excess 6mm & 2.5mm and 6metres 1.5mm grey twin and earth cable, plugs, sockets and grommets etc. Have basic knowledge of electrics just wanting opinions on using 2.5mm twin and earth cable a new 13 amp plug and fuse and a full metal double socket and back box mounted onto piece of wood for stability the lead will run a straight 5metres along the floor and will supply max 250w. No need for rcd as supply socket is on rcd mcb in cu. But can add 1 if needed? Any opinions?
