you get flame recognition across the electrodes ac currant coming from the pcb when rectified across the electrodes go back to pcb dc currant
Sultanas!!
what for ignition
call
fan runs
gas valve opens
pilot lights
main burner lights
gas safe engineer runs for cover.
missed a few steps for safety but you get the idea
corrected that for you.
what for ignition
call the boiler a t&&T
fans runs wild
a fart of gas the valve opens from behind
pilot lights a smoke
main burner lights are on nobody at home
corrected that for him.lol.
Hi, just an update, I waited until my regular boiler repair man came back from holiday so he's just been this morning.
It was a blocked injector which he's cleaned up and got it working again, he's also serviced it as it was due one.
Great price too, barely more than he charges for a normal service
Reactions: Toneyz
Just on the subject of flame rectification...i got to talking about this process,with a heating engineer pal,and he said the boiler manufacturer he was accredited for,just had a simple set of tests,to identify a rectification issue - then they replace the assembly.
He wanted to know the method of it's operation,and if each step could be tested.
I did this with him,and on the strength of it,he has purchased an AVO 410 Megger multimeter,which is what i used,in the demo :)
Just bumping this one again.
The boiler broke down again, had my regular repair guy out, it was the thermostat that had gone, he came yesterday and fitted a new one.
All working fine though now it keeps firing up a lot more like every couple of minutes. I spoke to the repair guy who basically said it was nothing to do with the new thermostat, see how it goes, it's a 20 year old boiler etc, wasn't really bothered as it's working.
Any ideas why it would be doing this? thanks
Boiler not firing up
Central Heating Systems
DIYfan,
DIYfan,
