Discuss Re-wire done other week, now require extra circuit. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
Carlos_tlewis
Hello,
I've never had this before so sorry for sounding silly...
I did a re-wire for a customer the other week, now they have decided they would like an outside socket.
Every things been tested, there's a spare way left on board so all I need to do is run a new circuit but what cert would I need to do for this? or would I need to re-test the whole board?
Thanks,
Carl
if it's a new circuit you need to fill out a EIC.for that 1 circuit. can you not add it to the scedule of test results. if you can come off an existing circuit, you only need a MWC.
That would be to easy hehe, I was going to do that but it's going to easier just do run new circuit because of location etc.
So I can just test that one circuit and leave all the other circuits alone and just issue a separate EIC for that one circuit.
Thanks, never had to come across this before.
as the rewire was only recently done, i would just add the new circuit to the schedule of test results on the rewire EIC.
Hello,
Thanks,
Carl
Isn't this job notifiable?
Reply to Re-wire done other week, now require extra circuit. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I sorted the fault fairly quickly as it happens but only because I'd come across it once before and at the time a few people said it couldn't...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
I’m just finishing my L2 2365 at college in the evenings and plan to do the L3 2365 with the same college as an evening course. However I would...
