Discuss Steel trunking in the UK Electrical Forum area at ElectriciansForums.net
daiplayer
Hi guys
Been asked to perform some remedial works on site....lot of which is Missing 100mm galvanised trunking lids missing.
Can they be bought alone ? ( as i cant find them ) or will the whole trunking section needs to be replaced ?
does anybody have any better ideas ?
ta
I've never tried to buy it seperate from the trunking, the wholesalers mat do but may charge a premium for it.
Maybe a look on the bay of E might get you some.
I have just re read your post even if you cant buy the lidding seperate , that doesn't mean you need to replace the trunking, just use the lid of the trunking you have to buy.
Then hope someone else comes along wanting a load of trunking without lidding. simple.
it depends on the lip really on the edge, if its similar to trent trunking but not quite right then you can buy camlocks seperate and manufacture some with a metal bender like laggers use.
best thing to do is take a picture and go along and show it to a couple wholesalers and on here to see if anyone recognises the brand
Hi guys
ta
Call in at your local CEF branch, they have a steel containment manufacturing division, who I'm sure will make something to fit for you.
Reply to Steel trunking in the UK Electrical Forum area at ElectriciansForums.net
Is anyone aware of any galv trunking that is smaller than 50x50. I'm drawing a blank online. I've taken over a job that's used 16mm twin and earth...
Hey all, Excuse the ignorance here but I wonder if you lovely folk might have any opinions or better still be able to point in the right direction...
7K
Is there a room in professional PAT testing for a business model other than 'per unit'? I ask because I've been giving this some thought. I've...
9K
M
Hi lads, bit of a random one. A friend has just bought a café and wants a few wall lights installed. There is already PVC trunking run high up...
4K
Hi all. Been reading a lot of topics in regards to grouping factors, none of which seem to have the exact answer I'm looking for. I'm currently...
dannydore
