Discuss Single Plug Socket replaced - PROBLEM!! in the DIY Electrical Advice area at ElectriciansForums.net
N
Nick Marsden
Hi, i have replaced my single plug socket and am unsure of something. I know how the wiring works as in red is live, black is neutral and yellow/green is earth. There are usually two of each to go in the terminals?
There are 3 earth wires and i didnt notice if all three were in the previous sockets terminal as it was all tangled. i have put the new socket on with all three earth in the terminal but it was a right squeeze getting them in. Is this unusual to have 3 earth? please help as im worried its unsafe.
You will most likely find that one of them is a fly lead to the metal back box.
If you're that worried get it checked by a proper electrician
Yes one is to the metal back box, but is it normal to have another two earth coming up with the other wires?
Do you have 2 lives and 2 neutrals?
If yes then yes it is.
Where are you roughly?
yes two live and two neutral. in blackpool. i checked another single socket in another room and it only has 2 earth, doesnt have one to the metal backbox
The fly lead is not a must have Nick.
I have to say, if you're not comfortable with this stuff you shouldn't really be messing around with it mate
i have changed some before but never come across three earth in a single thats all. changed a double in the same room and had two of each. earth had one on the back box and one coming up with the rest. just stumped me when i saw a third in the single.
up sh*t creek Geordie Spark??
So on another socket you had one CPC (earth) coming from a cable and the other was a fly lead? This needs to be checked Nick and by someone who knows what they're doing.
Geordie's just ribbing you. Don't worry about it, he's harmless
Usually :)
That socket could, of course, be a spur but it wouldn't do any harm to have it checked out just to make sure.
I'd also get the circuit in question tested too. Electrical safety is usually cheaper and less traumatic than funerals.
Yes there was one on the back box and the other going into the terminal. connected it identically as per the old socket so shouldnt be an issue, i hope. as long as the three in the single socket is fine then all good. have you ever come across three earth in a single? reason im asking on here is i cant get in touch with an electrician till morning.
Yes, I've come across it many times. I've installed many a socket on a ring final and put the fly lead in. However, how do you KNOW you have maintained continuity of all conductors? How do you KNOW that the insulation resistance is high enough?
There are more questions I could ask you but in the interests of not boring you I won't.
I admire anyone who is prepared to have a go at most things but only someone with access to calibrated test equipment and the knowledge required to use it properly can answer those 2 above.
You can't be too safe with electricity mate.
No i cant answer those questions. i will get someone round tomorrow. but from what ive told you, its sounds ok?
No reason to worry about a fly lead or the lack of one from a box to a terminal on a socket Nick.
Thanks for your help its much appreciated. one last thing, should it be tough to get the three earth onto the terminal as it was a right bugger but i got there lol.
Future father inlaw is an electrical engineer and is coming tomorrow to have a look.
You probably didn't have the terminal bolt out far enough, usually the trickiest thing about it is holding the socket in such a way that the 3 stay where you want them till the bolt gets hold of them, It's something that I struggled with when I first started my apprenticeship. Once you get the hang of it you don't even think about it.
I had the bolt fully out and it was the angle i held it that was the problem haha. like i say i couldnt say for sure if all three were in the previous socket. would it be normal for one earth to be left out and just sit there in nothing?
Only PROBLEM I see here is that you are playing with things you know diddly squat about, leave things alone before you burn your house down or worse kill someone.
I have to agree Ian
When people ask such basic questions why do certain people reply as the question is so basic the person asking the question is gonna get a belt of they seem out of there depth don't answer them .also if the father in law is an electrical engineer either ssh him or let him do the electrical work
Good, well thankyou very much for all your help :)
No problem but in future please get your father in law to do stuff like this as he'll know exactly what the crack is
I have to agree Ian
Had Nick come on asking how to do this I'd have told him pretty much what Ian did however, the job was already done so I was putting his mind at rest over a question arising from it. You'll see if you read the posts that I've told him that circuits should be tested and why
But he won't test anything .you retell them what to do they do it;it works " I am great "so they think
If I was around someone's house yes I would tell them if I was working with t h a plumber I would tell him bt on here no !
And why do you ask the plumber or carpet fitter or whoever a question when your working with one ? To save money they ask you stupid (not always ) questions to save money no thought of safety in it cos if you can't wire a ceiling pendant or put a plug on your not gonna test anything although I believe some one bought a light up screwdriver / tester ,now him I'd let work on 3 phase
But let's have a bit of sense cos when he gets a belt falls of a ladder and can't work he will say to lawyers for you " the electrician told me to do it "
Rant over ,well for now ; I'll start again in the morning just like my wonderful wife
Reply to Single Plug Socket replaced - PROBLEM!! in the DIY Electrical Advice area at ElectriciansForums.net
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
Hi all. I'm going to replace some sockets during a routine redecoration of our lounge including replacing some singles with doubles with USB...
Hi all. I just unscrewed the faceplate in order to replace the scoket and noticed that there is a red and a green wire going into the Earth...
I had to replace a surface plug socket box after the plasterer destroyed the old stuff. It has black, red and earth wire, 3 of each and look...
A rose in my 1970s kitchen ceiling became loose (one fixing screw had been inserted right on the edge of the hole in the ceiling) and when I...
