Discuss 10.5kw shower wired in 10mm twin n earth on a 40A breaker a problem in the UK Electrical Forum area at ElectriciansForums.net
G
giddash
Hi there,
I did wired 10.5kw shower with a 10mm cable on a 40A breaker for an old lady's bathroom.she recently got a builder in to do some tiling work and this guy thinks the wiring is wrong and that i should have use 45A breaker else the house will catch fire.I don't think his is right as there no way this could happen as I did test the breaker and it tripped in less than 5s but tought i should post this any way.
What was the length of run,what was your Zs reading ? what was the rererence wethod,clipped direct for instance and finally are you qualified?
Reply to 10.5kw shower wired in 10mm twin n earth on a 40A breaker a problem in the UK Electrical Forum area at ElectriciansForums.net
Good evening all, I’m currently part way through my apprenticeship and we are working on IB, IN, IZ and IT and volt drop today. And it got me...
Hi all, Was speaking to a family member recently, he told me his iron recently made a bang and flash as he plugged it in to the socket, and could...
Hi I'm looking for some advice for adding a time delay on my parent's shower room fan. My parents had a section of their garage converted into a...
Ok so live in 89 mobile home ugh I really need lots of work but I'm on disability and I cannot afford electrician but I've been working with all...
  • Locked
5K
