P
powervan
ok lads been having a discussion on Edf fit form! ive got job with following!! 1x 1.7kw on garage 1x 1.5kw on shed(outbuilding) now treated as sep systems due to distance ie impractible to run cable back to 1 x generation meter position! how do i reg it! do i do 2 mcs certs for same property? then 2 x Fit forms?
Guess so , unless Edf will allow you to insert both sets of info on 1 form , i have a system i'm installing next week with 2 arrays/inverters but plan on putting both on 1 circuit with 1 generation meter , not any issues with distance or cable sizing.
Lee
Know what you mean , probably just easiest to call Edf i guess and ask.
Good Luck
Lee
Do either of these pv systems connect directly to the main cu, or do they both go to sub boards?
garage 4 way board fed via 6mm to main board! shed/outbuilding 2way board fed via 4mm to main board! (both swa but long runs)
distance is the prob! its a big place garage one end of property outbuilding the other! just thought one of u lot would say EASY!! do this!! Edf fit form allows for 2 generation meter details so we go with that:)
2 generation meters?????????????
Thread Tags
powervan,
powervan,
