Discuss 2 x Megger testers for sale £230 Very good condition in the Electrical Tools and Products area at ElectriciansForums.net
T
TPES
Megger BM401/2
Product Code: BM401/2
Test button located on probe allowing the instrument to be perated manually.
Accurate and fast true voltage indication without the need for seperate multimeter.
Simultanious analogue and digital displays for maximum information.
Versitile instrument for many different testing applications - ideal for service or maintenance engineers.
Dust and moisture protected to IP54 for maximum safelt enev in the harshest of environments.
500V analogue / digital with voltage range.
  • Automatic detection of live circuits
    Automatically discharges after test
    Insulation tests at 1mA into rated load
    Continuity tests at 200mA s/c current
    Choice of test button - Locking / Non Locking
  • Fully meets all relevant regulations: BS7671, BSEN61557, EN61010-1 Safety Standard.
AND
Megger LT7 Digital Loop Tester
Product Code: LT7
Designed for repetative testing. Two wire set available for testing lighht fittings and at the distribution board
  • Guarenteed not to trip RCDs rated at 30mA and above - even electronic ones
    Using the latest technology the Megger LT7 is capable of measuring loop impedance without tripping RCDs rated at 30mA
    Low current range for RCD protected circuits
    Maximum loop test range 2000 Ohms
    Conventional high current (23A) testing with a 0.1ohm resolution
    Direct reading of PSCC and PEFC
    Operating voltage 50v to 263v, 50Hz and 60Hz
    Test light fittings with 2-wire lead set
  • Mains test lead and 2-wire lead set supplied with test and carry case
Click each link to see more info..
AND
Megger BM401/2
Both cost over £700 new!
Send me a private message if interested.
Both in there cases, each with there own test leads. I can send you photos if you like. £230
Reply to 2 x Megger testers for sale £230 Very good condition in the Electrical Tools and Products area at ElectriciansForums.net
Electrical2Go - Megger MFT Deals! Upgrade your toolkit with our exclusive offer! Purchase any of the Megger advanced multifunction testers –...
If this is posted in the wrong location, please remove. I am listing some items for sale that I have laying around. Everything listed below is...
Megger MFT1730 with Bluetooth. Calibrated until sept 2018: Used, but great condition. Comes with all accessories. Wanting £600 Ono Some spec...
W
Hi All, I hope I am posting this in the right forum, assuming that I am allowed to advertise items for sale here at all (sorry if this is the...
wulfruna77
W
For sale set of 3 kewtech seperate testers:- -Kt35 insulation resistance tester -kt45 loop and pssc tester -kt56 rcd tester all leads and probes...
