Discuss accenta alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
A
andy1494
hi there need some help or adivise, i have installed at home an old accenta alarm what version it is i dont no there no marking on it, what i am asking if possible the keypad has never worked, i taken all 6 wires when out of the blue the alarm went of, can i replace first the keypad with a normal accenta one + can i replace the old alarm box out side with a new one as when the alarm went off i pulled the wires out plus the box shatterd with old age any help please with this tia
hi there i have manage to swap the keypad, but i am lost with the new bellbox i just purchased an honeywell AG6 sounder & strobe but the connection on it are as follows =
ST
R
SW
V+
V-
looking at my old box the connection are as follows
ST + blue
ST - Green
SCB red = t
SCB Black a
BELL + yellow
BELL - White
and a red 13v black -
i am know lost how to wire this new box any help please tia
in my panel i have
strobe- = yellow
scb T = white
scb a = green
bell + = red
bell - = black
in bell box
stb- = yellow
trig- = black
hold off - = green
hold off + = red
rtn = white
hopefully this can help
in my panel i have
strobe- = yellow
scb T = white
scb a = green
bell + = red
bell - = black
in bell box
stb- = yellow
trig- = black
hold off - = green
hold off + = red
rtn = white
my old bell box i pulled all the wires out when it fell apart with age and i could not switch off the alarm
the panel if i am correct is
st + blue
st - green
scb red = t
scb balck = a
bell yellow = +
bell white = -
also red 13v + abd black 22 -
that why am lost
bell box
is it a intellisense
ST- = yellow
R- = white
SW = black
V+ =red
V- =green
at panel
STrobe + nothing on a newaccenta or optima
STrobe - =yellow
SCB = T = white
SCB =A = green
BELL + D= red
BELL - B = black
failing that mate not sure with it being a older panel you seem to have more connections at the panel
or buy a new accenta panel and wire as above
sorry cant help more try asking forum member alarm man
this is what i was told
this is what i was told to do
Panel AG6
T...... R
A..... V-
ST-..... ST
D..... V+
B..... SW
which meant i did
st - green
r red
sw - white
v+ yellow
v- black
First of all take a picture of the actual panel as there is about 10 versions of it basically this panel started life as a Optima 30 years ago and the latest editions are just updated versions of a good panel. RKP need to know what version you have.
Alarm going off when disconnecting cables Well yes that is the case the panel has a 230v supply that is transformed down to 12vdc so the alarm can activate with the power switched off and the panel battery is disconnected why because the sounder box outside has its own independant power cell or battery that will activate it when the power and battery is removed from the panel.
From memory, the Concept was the first Accenta panel to have a remote key pad, and that the new version of RKP is not backward compatible with the Concept. A new outside siren/SAB has the same connection arrangements in the main as older ones.
TBH, at the cost of the Accenta panels, buy a new one complete with LCD RKP and treat yourself to a new bell box at the same time.
Regards.
Reply to accenta alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all, Requesting your help please! I know this is an old system but has been working amazingly for 7 years! I had an engineer out who done a...
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
My pir cables are red+ Black - Yellow blue alarm or relay Yellow green tamper However one has different colours Blue Blue white Orange Orange...
After 24 years my septic lift station pump and high water alarm needs to be replaced. It was tripping the breaker and the alarm was no longer...
Hi I’ve recently installed a texecom veritus excel alarm system but having an issue with the sounder not going off when triggered by the pir I’ve...
