Discuss Adding fused spur for bathroom extactor in the UK Electrical Forum area at ElectriciansForums.net
Hi - I'm planning to fit an extractor with timer to a bathroom, switching on with the lights and had bought a fan isolator switch, but reading the Manrose instructions they insist on double pole fused spur with 3A fuse.
I think it will be easiest to fit a switched fuse spur and not bother with the fan isolator - this will be fitted outside the bathroom above the doorway.
Just figuring out the easiest way to fit this in since the extractor needs live and switched live.
Current setup
Suggested:
I have also seen options that suggest to use a double pole pull switch instead and then only the extractor fan is protected by the fuse - suggestions?
Current setupView attachment 39711
Suggested:
Dave do you have any electrical experience / qualifications etc it's difficult to tailor an answer if we don't know your knowledge.
no qualifications but do the jobs I think I'm capable of and leave more complicated stuff to professionals. Normally can understand if somethings explained in simple terms - TBF I've read a lot of debate about what I'm trying with many questioning the need for the fuse, but since the manufacturer stated it I'd prefer to go that route.
They do not ask for a fused spur but do say it should be installed by a qualified electrician.
PUB0347_iss01_ID_Axial_Fan_ECO150.pdf
"In fact they say must.
NOTE: All wiring must comply with current Regulations. This system must be installed by a qualified electrician.
  • PUB0347_iss01_ID_Axial_Fan_ECO150.pdf
it actually says 'must be supervised by a qualified electrician' - and yes a fairly clear warning which I'm sure their legal team insist is put in to stop them getting sued if someone who doesn't know what they're doing injures themselves.
Happy to hear any suggestions if what i suggested is dangerous or incorrect? First thought was to check with people who know best how complicated a job it is, since when I checked the price quoted for wiring up the fan was around ÂŁ200, and since I've got 2 to do, and it's only electrics needed since roofer is fitting the vent tiles and I'll mount the extractor and fit ducting etc seemed quite steep - but if someone can explain briefly maybe it will make sense.
Thanks for input so far.
Isolate the main supply before making any electrical connections. This system should be installed by a qualified electrician. • Whenfittingthroughanexternalwall,anexternalgrillemustbefittedatalltimes. • Fanshouldonlybeinstalledbyfixedwiring,aflexiblecordshouldnotbeused. • Theapplianceisnotintendedforusebyyoungchildrenorinfirmpersonswithout supervision. • Youngchildrenshouldbesupervisedtoensurethattheydonotplaywiththe appliance. • Precautionsmustbetakentoavoidtheback-flowofgasesintotheroomfrom theopenflueofgasorotheropen-fireapplianceswhenmountedinoutside windows or walls.
if a have a problem with my car .do I play with it or get some knows about cars!
Depends on you really doesn't it? I saw a chap paying halfords ÂŁ10 to change his indicator bulb recently - would you have done it yourself? Is the halfords person 'qualified'?
Thanks for the copy and paste but I've got the correct instructions right in front of me - I have read it.
If this is meant to be a lecture then thanks. But, I've just looked at instructions for fitting some downlights:
This light fitting has been designed and manufactured exclusively for B&Q These instructions on wiring and installation are provided as a guideline to assist you. Some experience of electrical wiring and do-it-yourself is required to install the light fitting. If at any time you are unsure of how to proceed, please consult a qualified electrician.
So I'm safe to do the lights, but not the extractor?
Oxford dictionary " anyone who installs operates electrical equipment is an Electrician"
Reply to Adding fused spur for bathroom extactor in the UK Electrical Forum area at ElectriciansForums.net
Looking at instructions for installation for Baumatic BHI300 it requires a 20A Double pole (3mm separation) switched fused spur, I quote pretty...
Good afternoon everyone. I have fitted an extractor fan in my bathroom with an overrun timer, to start when the bathroom led lights are turned on...
8K
Hi all, wonder if someone can help me. I've bought a bathroom extractor and I do have the wiring there already (previous extractor was there) but...
Hi all, I recently bought a new house and I went to check the installation on my garage. There is a double socket and a fused switch (3A) which...
Hi to all, If extractor fan in bathroom is autonomous does it still require isolator switch or usual fused switch will do? It runs of 12v...
