Discuss advice for a newbie - Heat Mat (underfloor) in a mobile home in the UK Electrical Forum area at ElectriciansForums.net
T
The General
I've been asked to go out and look at a job - wiring in a Heat Mat to go under some tiles (bathroom I think, but not been out to visit yet.)
Firstly, I've never done one of these before, so any pearls of wisdom would be greatfully received.
Secondly, I'm assuming that a 'Park Home' (static caravan) will come under the Special Locations section - or is that just 'mobile' caravans?
Obviously I'll need to read the instructions that come with the mat/control unit, but I'm guessing that it'll need a (switched)FCU to feed it. Is it likely to need heatproof cable like you'd fit on a storage heater, or will standard PVC cable be okay?
Also, if it is in the bathroom, would it be better to have the switch & control unit situated outside the bathroom as I'd imagine that it'll be a pretty small room, so might struggle with zones!?
I always say that "You don't know what you don't know..." so apologies if I'm asking daft/obvious questions, but I figured it was best to arm myself with all the information before I go out!
Many thanks in advance for any advice/guidance.
Well a "Park Home" that is static certainly does not come under classification of either a "Caravan" or a "Mobile Unit" in the BS 7671-2008 definition section, and as always been a source of discussion on many a dull night.
Not sure what other bodies of authority feel
peice of cake!! measure room M2 buy heat mat to suit size roll it out (peel off paper) stick it down wires back to heat stat on wall wire from that to supply (rcd spur) TEST IT your done get paid
Reply to advice for a newbie - Heat Mat (underfloor) in a mobile home in the UK Electrical Forum area at ElectriciansForums.net
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
Hi all looking for some advice as a non sparky , be gentle :) To be clear I wont be doing the work myself , just want to be better informed. I...
After a bit of advice please, been doing some work for ladies of a WI group and they have asked me to look at the heating / electricity...
I found myself needing to do some emergency plumbing at home this evening. I've got a small guest flat on my property which has been empty for...
