dichroic
Can someone tell me where in the new green book it gives the maximum disconnection time for a circuit on a TN system when there is likelyhood of contact from livestock? I just can't find it ?
Dichroic
don't think there is a specific time in the regs. however, 705.411.41... RCDs, so the disconnection times applicable to the RCD/s will apply.
Agricultural with contact with livestock not allowed a TN system, must be TT.
Section 7 something.
Edit: Sorry Tel's right
Reactions: 1 person
Thanks guys............to clarify;
Protection against shock may be provided by
1: ADS with additional protection by rcd (30ma) for final circuits supplying socket outlets rated at 32A or less.
2: ADS with additional protection by rcd (100ma) for final circuits supplying socket outlets rated at more than 32A.
3: ADS with additional protection by rcd (300ma) for all other circuits.
OR
by the use of SELV or PELV.
Where does it state that TN-S systems cannot be employed?
Regards
Dichroic
It doesn't, only a TN-C system is prohibited.
In locations intended for livestock, supplementary bonding shall be required.
See Tels post ^^^, it doesn't, it says TNC-S/PME is not recommended where there is no metal grid laid in the floor Sec 705.
And for ADS the 0.2s has been removed, replaced by the requirement of RCD's
BS7671 Green Book
dichroic,
dichroic,
