Discuss Earth not connected on a socket in the DIY Electrical Advice area at ElectriciansForums.net
MikeeF
I was going to swap a socket in my house for a socket with USB connection. I started to remove the socket and noticed that both earth wires from both cables (part of a ring main) are wired into the metal back box and no earth connections into the actual socket see photo. Now I'm sure this is incorrect and the earth wires should be connected to the socket? The house is 2 years old. Thanks Mike20221112_191220.jpg
That is definitely incorrect however it would have an earth connection once screwed back in place but this may be tenuous. Both of those earths need disconnecting to the socket front plate. It is essential the other sockets are checked.
Thanks. I will move the earth's to the socket. Luckily I distributed have anything plugged in that socket.
25mm box where there appears to be plenty of room for a 35mm!
A good electrician would also add a wire between the socket earth terminal and the terminal on the box.
Is that socket on the picture a USB already?
This square part here?
I’m with Westy.
Check all your sockets. In fact… check everything. 2 years is still under the NHBC warranty period… although that’s not always worth the paper it’s written on.
Look out for missing brown sleeving behind lightswitches.
And loose cables.
Please isolate any circuit before taking fronts off
Might be interesting to see the consumer unit,
I’m with Westy.
And loose cables.
No it's not a usb. Yes I will be checking all sockets now.
Reactions: DPG
Reply to Earth not connected on a socket in the DIY Electrical Advice area at ElectriciansForums.net
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
Hi all. I'm going to replace some sockets during a routine redecoration of our lounge including replacing some singles with doubles with USB...
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
Hi all I would like to put some sockets in the attic and keep them on the main house ring main. Am I right in saying I can pull one of the legs...
