- Reaction score
- 16
Hello,
Recently been tasked with putting in a supply for a hot wash (pressure washer) This is quite the beast, diesel powered for the heating of the water and small 1Ph 230V supply for the actual pressure side.
Bit of background, will be supplied via 10A C type MCB fed via 3C 2.5mm2 SWA to a IP67 16A plug and socket with RCD protection on the socket then via some 3C 1.5mm2 H07 to the pressure washer it will be housed inside a small wooden shed (for me to make...) Fed from a board inside, pressure washer will be outside, 10m max.
But I've just been told by one of the old hands, that this needs to supplied via a earth proving socket (Basically checks for the continuity of earth) Never really heard of one before Im un-sure if this is true or not? And couldn't find a reg that applied? Anyone got any ideas/regs or help to say if this is needed or not? or just legacy stuff?
WS
WS
