Search the forum,
Discuss EIC - help please in the Australia area at ElectriciansForums.net
Hi All
I have just installed a distribution circuit from Farm House to Mobile Home - straight forward job in SWA via Henley block and Switchfuse etc.
The Cut Out was 60A feeding 3036 fuseboard no circuit charts/labels etc typical farm installation.
My qusetion is what do I put in the tick boxes regarding presence of diagrams/danger notices/mixed wiring colours etc. Is it acceptable to put n/a surely I can't be expected to identify & label every circuit of the whole farm house if only installing sub main?
Also other tick boxes regarding routing of cables in prescribed zones?
Thank you
Hi All
Thank you
cross in the box and mention it in departures
No you do not mention it in departures, you mention it in comments on existing installation.
Precisely and the schedule of inspections is strictly covering YOUR WORK so why would you want to put crosses in if your work is compliant?
On the EIC, "Extent of the work covered by this certificate", Distribution circuit from Farm house to Mobile home CU ONLY. You can then tick all the relevant boxes, you shouldn't have any crosses in any boxes if you have installed a new circuit, just ticks and N/A's. As long as your work is compliant, then all is well. You have no responsibility for the circuits coming out of the mobile home CU.
Cheers.......Howard
Cheers.......Howard
Thankyou - that makes more sense, I distinctly remember reading that NO crosses or LIM's should be on an EIC only PIR's - yes all my work on SM is compliant.
Reply to EIC - help please in the Australia area at ElectriciansForums.net
Long time lurker so this may be my first question. I am a qualified electrical engineer, but in aeronautics not domestic installations, and I may...
9K
Evening all. I have a question as I can’t get my head around something with solar PV I’m going to be working on a new build in a couple of...
Hi, was wondering if anyone could help me please. just re sat my am2 testing exam but failed because i didn't verify my results correctly to the...
4K
Background: I have a ex council 1st floor flat that I bought, I moved in to care for my disabled mum and so rented the flat as I could not do...
5K
So I'm an aquarium enthusiast and I have several fish tanks in my house (all of them have lights that are connected to timers). My basement has...
