Discuss EPC Solar Thermal in the Solar Thermal Advice Forum area at ElectriciansForums.net
I was totally shocked to find out when registering a solar thermal and a heat pump installation we carried out that no EPC is required, how an earth does that work when they both involve heat loss, yet pv producing electricity requires it? Proof they are trying to kill the pv industry :61:
You may see something when the domestic RHI is introduced next year. The reasoning behind the EPC for PV is the old saying 'insulate before you generate'. Greater savings can be made through reducing enregy consumption in the first place. The difficulty is that EPCs are a bit of a blunt instrument and do not take in to account what is practical for any given property. In time alignment with the Green Deal assessment instead may be a way forward.
With regard to heat technologies, if they are being used for space heating, improving the thermal efficiency of a building first is a no brainer. Where they are being used for water heating, the case is a little different. The thermal efficiency of the building does not affect hot water usage. Hot water usage should be the same for a tent or a passivhaus of similar size and occupancy levels. It is hoped that DECC can be persuaded to concentrate on the efficiency of the hot water system itself by ensuring high levels of tank and pipe insulation, and properly regulated flow rates in showers. Time will tell.
Reply to EPC Solar Thermal in the Solar Thermal Advice Forum area at ElectriciansForums.net
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Hi, I've got both a solar pv and an ashp system. The solar system also has 2 batteries and it's configured to fill the batteries first and then...
If one of your coworkers suffers a severe electric shock, your first instinct will most likely be to rush to their rescue. But first, pause and...
