Discuss Escape route in dwellings fire clips and best methods in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
So have been trying to find the best method for containment of multiple cables above escape routes in dwellings (hidden in the ceilng) the little red pre fixed fold over clips look like a pain in the ---. Was wondering if there is a better method (similar to the conventional clips) and If anyone can clarfy what is required with regard to the reg.
I didn't think it applied to dwellings, however, nothing stopping you going further than BS7671. Unless this is not for a volume development for quickness carry on with standard cable clips and in places could use banding.
I think it does apply to dwellings also, though now starting to doubt myself! If it doesn't it should, as this was one of the better inclusions with AMD3 IMO. Maybe the firefighters that moonlight as Kev Kitchen on their days off will start to appreciate proper sparks a bit more now and utilise our services, seen as we are trying to keep them alive!!
Anyway, I use a combination of DLine fire clips and PVC coated galv band. The DLine are flaming expensive though... Metal P clips should be ok too. If I had multiple cables together I would use all round band probably.
Not applicable above a fire rated ceiling, if ran below the ceiling above an exit on surface then meta fixing must be used. Could use galv conduit as another option. D clips inside pvc trunking would be my choice
Reply to Escape route in dwellings fire clips and best methods in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi. Could anyone advise on the types of fixings / clips they are using to comply with: Wiring systems shall be supported such that they will not...
15K
T
Hi Guys, I am looking for some "practical" advice for a Fire alarm installation. The building is a 3 story 5 flat HMO (HMO only due to 1991...
Hi, I am trying to prepare a quote and am wondering the best way to approach this particular installation as it is not something I have...
M
Hi all, Can anyone help me with this one... I am about to be commissioned to install a fire alarm system in the communal area in an HMO. I...
5K
mattcos1972
M
E
I think I've Posted this before, but I've just updated it. Some of the sparks where I work still get a little confused of what the different areas...
77K
