Discuss Fitting an LED Spot into a loft hatch? in the Lighting Forum area at ElectriciansForums.net
Hi nicebutdim,
Please don’t use CHEAP push fit connectors.!
FLEX doesn’t connect well with Push Fit connectors ( hence why we use Feral's ).
Lever operated Wago may perform better.
But Feral crimping is more acceptable.
You do realise there are push fit connectors that work with stranded cable right?
I'm sure nicebutdim does.
CAPS AND !!!! over the top punctuation here !!!!!
Of all flexible cords that come to mind SY must be the least flexible.
SY gave the required mechanical protection of the movement from the loft hatch.!
20/25mm conduit wasn’t suitable in the space available.
Flex didn’t meet the mechanical movement of the operation of the loft access being operated over and over again. Also the fact that clumpy feet using the loaf steps made me want to possibly over engineer the requirement. Safety first.
No it doesn't, SY is mechanically not very good at all. And for that apllication you need good flexibility which SY doesn't have.
Yes it does, it's flexible cable, the clue is in the name!
A decent rubber flex is far more suitable than SY, with the advantage that rubber flex will actually comply with UK product standards.
Hi nicebutdim,
Ferrules shouldn't be used for push fit connectors.
On my first original inspection of the loft I noticed a number of mice and squirrel 🐿 traps.
There was evidence of 🐿 🐭🐁 activity, so for that reason I over engineered the materials used.
I’m grateful for the lesson, and now understand that Flex, is flexible.
But possibly not as 🐿 tolerant as SY.
Would you agree?
Would you agree?
SY cable is not suitable in fixed wiring applications that require compliance with British Standard 7671.
Reply to Fitting an LED Spot into a loft hatch? in the Lighting Forum area at ElectriciansForums.net
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hi My 4 bed 2 storey house was extended 2 years ago and completely re-wired, but I am having to upgrade the insulation and board out the loft...
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
