Whisk / stuffers / bandgo / wago.You fed a downlight with sy? How did you terminate it?
As the loft hatch is moveable it requires more than just T&E.
I would prefer flex in a domestic environment rather than sy which requires a proper brass gland to terminate and cores need sleeved. Using flex negates the need for both of these. The braid is utterly useless in this situation also.Whisk / stuffers / bandgo / wago.
Hi nicebutdim,Incredible that this needs to be related to an electrician through their customer - especially given how easily conductors slip out of those cheap push fit connectors.
Hi nicebutdim,
Please don’t use CHEAP push fit connectors.!
FLEX doesn’t connect well with Push Fit connectors ( hence why we use Feral's ).
Lever operated Wago may perform better.
But Feral crimping is more acceptable.
SY gave the required mechanical protection of the movement from the loft hatch.!Of all flexible cords that come to mind SY must be the least flexible.
Never wishing to offend, just to help.You do realise there are push fit connectors that work with stranded cable right?
I'm sure nicebutdim does.
CAPS AND !!!! over the top punctuation here !!!!!
But you did mention cheap push fits.
APOLOGISES.
No it doesn't, SY is mechanically not very good at all. And for that apllication you need good flexibility which SY doesn't have.SY gave the required mechanical protection of the movement from the loft hatch.!
Flex didn’t meet the mechanical movement of the operation of the loft access being operated over and over again.
Ferrules shouldn't be used for push fit connectors.Hi nicebutdim,
On my first original inspection of the loft I noticed a number of mice and squirrel 🐿 traps.No it doesn't, SY is mechanically not very good at all. And for that apllication you need good flexibility which SY doesn't have.
Yes it does, it's flexible cable, the clue is in the name!
A decent rubber flex is far more suitable than SY, with the advantage that rubber flex will actually comply with UK product standards.
Please send me a picture of a Push Fit connection unit, that used use with stranded flex.You do realise there are push fit connectors that work with stranded cable right?
SY cable is not suitable in fixed wiring applications that require compliance with British Standard 7671.On my first original inspection of the loft I noticed a number of mice and squirrel 🐿 traps.
There was evidence of 🐿activity, so for that reason I over engineered the materials used.
I’m grateful for the lesson, and now understand that Flex, is flexible.
But possibly not as 🐿 tolerant as SY.
Would you agree?
Please send me a picture of a Push Fit connection unit, that used use with stranded flex.![]()
