Discuss Help Identifying a Fuse in the UK Electrical Forum area at ElectriciansForums.net
Heya Folks,
I've been sent the following photo by a client and they want me to go round and fix it this afternoon. Apparently one or both of these has gone. Does anyone recognise them and know where I can get replacements?
Thanks,
Craig
It would help if you pulled out the carrier then looked at the fuse :)
After a bit of checking I think each holds a cartridge fuse, would this be correct?
Have you looked, as it might hold a paper clip for all we know.
Thanks everyone! It did look odd. There is an isolation switch that comes from the fuse board and then goes into these then into a large 3 cooker arrangement. Should I change the fuse for the moment and recommend that they change it?
I would strongly urge you to investigate further before energising that, especially if it connects to 3 ovens, gasp
Looks like a royal DIY lash up to me!! Why the hell are fuses at the wrong end of the cable? Would be a good place to start checking!! If the supply cable size to the isolator switch is suitable, then all you require is a dual connection unit/plate if both these ovens are actually ovens and not cookers!! lol!!
looks to me like the fuses are positioned where they are to protect the 'smaller' appliance cables
Edit: Ignore - I see what you mean.
could well be that, phil. converted to gas cookers and replaced the redundant cooker switch with that lash-up to fuse down to the clocks/igniters.
Reply to Help Identifying a Fuse in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I'm wondering if anyone might be able to help. We have a fused switch that controls 4 LED lights next to a power socket which have both...
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
About 15 years ago, after having had a modern consumer unit fitted, and prompted by our electrician, I asked my then energy supplier (Tonik) if...
5K
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
