B
bentleds
Just looked at a domestic call out. Storage heaters have stopped working. Next to the consumer unit is a Horstmann 80A timer clock, you know the typical steam punk Bakelite. This looks burnt out. Any recommendations for a replacement. Not familiar with this type of circuit arrangement.
If the unit is no longer available, a new timeclock and a contactor might be your way forward.
i'd be inclined to go with post #2 and use a lower rated timer to energise a contactor.
What is the total load of the s/htrs? Are you sure the t/switch belongs to the customer and not the DNO?
Picture would be good.
it is between customers CU and the storage heater fuse box. I couldn't imagine the DNO would have equipment there, but you never know the history. Flats were built in 1950/60s. All the meters are in a switch room downstairs. If they are not on an economy tariff I'll just take it out and replace with an isolation switch.
No it sounds like its a single riser that is split between the General consumer unit and an off peak timer , this would be the customers equipment , the off peak meter is located in a separate cupboard elsewhere , I would say the same as Tel , replace old timer with a timer and suitably sized contactor for the off peak board and set it the same time or within the off peak times of the off peak meter...
Email
Time zone
Last seen
horstmann 80A timer for storage heater circuit
bentleds,
Anthony S,
