Discuss How does this outlet box work? How to split a cable? in the DIY Electrical Advice area at ElectriciansForums.net
James TF
I want to install this set-up on my terrace (the plug goes into a dry closet). E.g the outlets are permanently installed, but the plug for them I'll just disconnect when not in use.
The wire is 1,5m2, and will only be used for phone charges and lightning so having both outlets on one wire is not a problem.
Questions:
  1. How should I split the wire like shown in the diagram? I'm sure they sell some thing designed for this - for outdoor use?
  2. How am I supposed to connect the outlet shown in the photo? I guess one wire goes to number 1, the other to number 3. But I don't understand the ground situation here? What is the purpose of number 5? It's not connected to anything? Does the neutral wire connect under the screw in number 6?
5 is probably a loop terminal and can be ignored. Earth goes to 6, blue and brown go to 1/2 and 3/4 not sure which way if polarity must be maintained but they are not marked from what I can see with L and N.
Reply to How does this outlet box work? How to split a cable? in the DIY Electrical Advice area at ElectriciansForums.net
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
Our family room is part of an addition built a few years ago. We had an issue with nuisance tripping on an AFCI and the electrician came and...
Thank you in advance for your help. I recently purchased a home and while removing some built-ins I found that they had a 14/2 wire running...
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
