Discuss Is this practicable? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
sivoodoo
Is the following scenario practicable and does it meet regulations?
A garage consumer unit with two 32A MCBs and one 63A/30maRCD main switch supplies two ring mains in 2.5mm T&E fom each 32A MCB.
This garage unit is fed from a 45A minitrip mcb in an old wylex board using 4mm T&E. (Distance from garrage unit is 300mm)
The main supply is PME
Each ring serves 6 twin socket outlets.
Your thoughts please
Simon.
Hey.
Splitting the tails with henleys is best IMO. You can use a larger earthing conductor also, i.e 16mm tails and 10mm earth, as opposed to 10mm T+E with 4mm earth.
Cheers
Reply to Is this practicable? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
Hi, just helping someone out and apologies for the long winded post. Would like install a couple of weatherproof double sockets on the patio. 1...
Hi I am carrying out an EICR. I have a garage mini sub DB supplied via 2 x 2.5mm T&E equivalent 5.0mm protected at main DB by a 32A mcb. I know...
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
