Discuss LED Lights - Transformer and Lights getting very hot in the Lighting Forum area at ElectriciansForums.net
Hi All
Help...
I have a strip of SMD 5050 LED lights - plugged in to a 12v transformer - and both (the LEDs and Transformer) get very very hot to touch. They take about an hour to slowly get up to the high temp - and sit there at that high temperature. The strip has been cut from a 5m length - down to 3.5m.
So my logic is this -
- each light draws 0.24 watts
- 60 lights per meter
= 14.4 watts per meter
- 3.5 m strip
= 50.4 watt total
So the 12v transformer needs to be rated to 4.2 Amps. I am using a 5 Amp transformer.
Have I got the above correct ?
Can anyone shed any ideas on why they are both getting so hot ?
When you say hot, how hot?
Many plug in transformers are designed to run up to 50degree C
The transformer is at near full load so will be running close to its design temperature.
When you say transformer, is it an LED driver or is it actually a transformer?
The wattage of the individual LED chips is usually a nominal rating, it's a bit dangerous to calculate the power of the strip by basically multiplying the wattage of one of the LED chips by 210. It would only require a very small error on the single chip wattage to give a very large error on the total wattage (the error would also be multiplied by 210).
Also I'd usually specify a driver that can deliver at least 1.5 times the Watts stated on the LED strip.
Reply to LED Lights - Transformer and Lights getting very hot in the Lighting Forum area at ElectriciansForums.net
I have halogen lights in my kitchen under the wall units, there are ten lights altogether bulbs are either 10 watt or 20 watt G4 bulbs ( not sure...
I am lighting my workshop with LED's. I had all 13W (1500 lumens) but wanted more light on the benches, so ordered some 23W, which is supposed to...
Hi Forum people. First time post here. I have a pair of semi flush fittings that are currently 10 Halogen capsules per fitting. I want to...
I am trying to put some led light strips under the fenders of my fat tire E-bike. I’ve been looking at led light strips on Amazon, AliExpress and...
Hi, I have bought a LED Lighting Strip (20 metres) to sit inside some Screwfix coving for my bedroom. Although it will be controlled by the...
