Discuss Looking for a 350ma 6w Driver in the DIY Electrical Advice area at ElectriciansForums.net
mike78
So as the title states and this turned out to be harder than it sounds task, been trying to find a driver for an LED fixture I have that came without a driver. It requires 350ma at 6w and 17v. I cant find the exact driver with these exact specs but wondering if 300ma will work or if 8 watts will work. the voltage is not always advertised and not sure if this will also be adjusted depending on the bulbs draw as long as the ma and watts are reasonably close to the required specs. Any recommendations on a driver is greatly appreciated.
You need to match the current, 350mA is quite a common value. The voltage will adjust to drive that current through the fixture, so long as the driver is capable of it.
A little higher wattage driver will just run at the 6W, but be aware a much higher wattage driver will be capable of putting out much higher voltages (can be several hundred V) that the fixture might not like.
Reply to Looking for a 350ma 6w Driver in the DIY Electrical Advice area at ElectriciansForums.net
Hello, I’ve have some ten year old Collingwood SL020 RGB led garden spike lights which I’d like to keep using but wondering if I can use them with...
I am looking at installation of an architectural dimmer, that is will supply 6 channels, with 20A circuits each (2400W ea). Our hall has can light...
Hi Everyone, I'm new to this forum and am hoping someone can give me some advice, as I'm absolutely clueless when it comes to these things. I'm...
Hi, I think I need to state that I'm a DIYer? I have A-level physics and tinker with vintage audio gear but I'm no professional electrician...
Hi gents Just joined and this is my first post. I’ve decided to upgrade my home garage compressed air setup since my current 3hp 50ltr 8cfm...
6K
