- Mar 14, 2013
- 25,716
- 18,746
- 18,688
- 79
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Retired Electrician
- Business Name
- None
Just thinking back to my Apprenticeship time, and working on a Large luxury Housing development, the chap I was working under, was a strict, but knowledgeable Electrician.
At the time in question we used metallic oval conduit for our switch drop and sockets etc., one of his rules where possible were that all switch drops had the conduit cut to the same length and the same for the runs from the floor up to the socket positions, during the first fix he would always inquire as to which make of sockets we were going to used for the second fix, so much so that he insisted that if the L was on the right hand side of the accessory, I had to feed the 7/029 cable up the conduit , with the L on the right hand side, didn't think it mattered all that much, until you came to install the socket, and how much easier it was with the cables entering the back box all on the same side.
Anyone else got any odd little tips that they were taught, that may have gotten lost over the years?, another one was marking the lighting cables at the ceiling rose, switched pair with a cross and the feeds in and out with a split at the end for identification, simple things I know.
