Djlelectrical
When installing lights would you change meter tails from 16mm to 25mm. Customer doesn't want to pay for upgrade main service fuse is 60a
Discuss Minor Works and Meter Tails in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Even if its not as per the regs ?? they recommend 25mm
Bonding is fine and up to date, The 16mm tails will carry roughly 85 amp so im not bothered about that.. its a case of weather its acceptable to issue MWC if the tails are not as per the regs
Its a TNCS, just beating myself up with the regs as they state minimum 25mm
Reply to Minor Works and Meter Tails in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
