Discuss Need advice on changing the plug on my welding machine in the The Welcome Forum area at ElectriciansForums.net
L_K90
Hi everyone hopefully someone on her can offer sound advice on an issue, im a welder by trade and have just purchased my first welding machine for home use, the power supply is rated at 16 A and the plug is a two pin moulded plug ive looked everywhere and even contacted manufacture and they said just cut plug off and wire 13 A three pin plug im unsure of this as it dosnt seen correct what issues could I face using a 16A rate machine on a 13A plug. Thanks
Having said that most Mig welders , if it is a mig , run quite happily on a 13amp plug in most small workshops . My mate has a 130amp mig in the garage workshop used daily with no problems.
The manufacturer would not tell you that if they thought they would have a comeback.
Above posts are the ideal solution though.
My welder is 180amp mma and tig welder someone did suggest instead of putting a three pin 13A plug on it I could put a blue 16A industrial plug on it so I can run it of generator and get adaptor for 13 A use not sure which option would work best as I want to get the most out of the power range
If you fit a 16A plug to it then use a 13A-16A adaptor to plug it in then you might as well just have the 13A plug on the machine.
The soloution, if it does need a 16A supply, would be to have a 16A socket installed on its own circuit.
Althougn you can purchase welder/generator sets, I would check with the manufacturer's first before running a standard welding set off of a generator.
I also run a 180A mig welder on a 13A plug.
Reply to Need advice on changing the plug on my welding machine in the The Welcome Forum area at ElectriciansForums.net
Hello, I'm seeking some advice on an overheating plug adaptor please. Complete amateur so please forgive any errors in calcs / assumptions /...
Hi Everyone, I have recently purchased a spot welder- Celette Scorpion 2400R. Plugged it into my three phases and it blew fuses(3x20A) with the...
Hi, I Bought a 32A EV Charger, it comes with a CEE wall plug. I need to use it with a 60A range recepticle which I use to plug in my welder. So...
  • Locked
5K
Hi there, Wondered if someone could advise as not good with electrics! I have an expensive Xmas tree which is pre lit. It decided not to light...
