Search the forum,
Discuss New member with electrical regs question. in the The Welcome Forum area at ElectriciansForums.net
3_fall
Hey guys,
I’m Marc, admin over on the tilers Forum. :D
Quick question if I may please.
In middle of Tiling shower area in an ensuite and the electrician has put a fused spur opposite the shower head for a towel rail, can you tell me if this is within regulations please.
The distance between each wall is 2.35m and I’ve attached an image to show its position.
The red circle right side shows the spur location.
Thanks very much.
> 0.6m from edge of shower tray will comply (out of zones).. if there's any danger of water splashes to the FCU< then a IP rated one should be fitted.
What putting the FCU outside the ensuite, and flex outlet plate inside. Just in case the FCU gets showered, and house owner turns it on stood in pool of water, silly billy.
Incidentally Marc, those tiles look cracked to me, or someone's not been careful with their hob nail boots :)
It is fine but I would have the FCU outside the room and then an outlet plate for the rail ................
Done that plenty times too but not always possible.
Is an outlet plate any better in terms of IP ratings than an unswitched FCU though?
Nope, but there's no reason to touch a flex outlet, and as most towel rads need a switch, why not put that somewhere where someone is not likely be stood on a wet floor?
I know are European cousins have a more laissez-faire attitude to these things, but isn't that the reason we're leaving them :)
Reply to New member with electrical regs question. in the The Welcome Forum area at ElectriciansForums.net
If I’m correct in saying, you can have an electric towel rail over your bath in zone 1 as long as it has a IP rating of at least 4 but the fuse...
We're having an electric towel rail installed in bathroom, outside any zones It's just above the stairs with a clear wiring run to under the...
12K
Hello all, I’ve recently moved house and I’d like a little advice on the safety of some of the wiring found. In general the wiring looks...
8K
