Discuss Panel Convert 230 - 24v in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
C
Corvus
Hi all
Just been asked about if I can make a replacment panel for a company. The old butchered panel is 240v control.
Is there any rule of thumb or so to work out what size of transformer to use to convert it down to 24vac.
I have know idea how much power contactors,relays and indicator leds take.
There will be 15 or so contactors with about 9 Led panel lights with some e/stop relays.
any ideas ?
The info is available from the control gear manufacturers website, If stocked then RS components/ Farnell data sheets are a good source too! So basically you need to know whos gear you're going to use and take it from there.
Hi all Just been asked about if I can make a replacment panel for a company. The old butchered panel is 240v control. Is there any rule of thumb or so to work out what size of transformer to use to convert it down to 24vac. I have know idea how much power contactors,relays and indicator leds take. There will be 15 or so contactors with about 9 Led panel lights with some e/stop relays. any ideas ?
can you show a pic of the old(opened up) panel?
Reply to Panel Convert 230 - 24v in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all I am new to this forum and hope this is right placed and of interest. I would like to make a setup with one or more impulse relays...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
Hello, this is my first post here. I have a little experience with most types of household wiring through a decade of DIY remodeling, and...
