• Electrician Forum
    Welcome to Electrician Forum. We started out on April 22nd 2006 and used Electricians Forums as our brand name which is an unregistered trademark.
Jun 20, 2017
37
Saudi Arabia
Dear all,
We have 460V MCC panel for existing pumps in our plant. We need to give supply to new 380V rated pumps in the same panel. There is space available in the panels(Out of 9, one panel almost free). So please suggest is it possible to make the arrangement for MCC feeders in the same panel.
Regards,
Aamer.
would a 460V/380V transformer be a solution?
  • Agree
Reactions: 1 person
As above fitting TXs or inverters rated to incoming voltage and programmed for 380v outputs...we lack info to go any deeper.
Dear all,
Regards,
Aamer.
Got any pictures of said panel?
Is frequency the same?
OP?????
Anything I've worked on like this has involved inverters, have you any other information?
I think the OP came and went,we have had no reply since he originally posted it over 2 weeks ago.
Saudi Arabia
Power supply to 380V pumps from 460V panel
Electrician Forum
Syed Aamer Hussaini,
