Discuss Protection against open/loose neutral? in the UK Electrical Forum area at ElectriciansForums.net
Hello friends, is there such a thing as a "smart meter" that I can install on my backwoods house that will trip if it detects a loose/open neutral? If so, where can I get one? Thanks very much
Hello Kevin and welcome to the forum and yes they make smart meters but that’s the meter the power company puts in. The meter is called a smart meter because the power company can read it without ever coming on your property. Are you having some kind of problem that you need help with. You can buy GFCI breakers that could do what you want
A high resistance neutral connection is usually manifest by incorrect voltages - on a single (split) phase supply one hot-neutral voltage goes up (the one with more load) and one goes down while the hot-hot voltage is unaffected, similarly for 3-phase.
This is easy to detect; for example you can buy voltage-sensing relays that can be set to trigger an output when the voltage goes beyond settable limits for a certain duration. These could then operate a shunt-tripping add-on unit to a main breaker, to isolate your panel from the faulty supply. (There are complications in practice, such as making this run from the hots only, so that the failed neutral doesn't stop the protection working).
Perhaps there is an all-in one unit? As MW says, is this a precaution or are you experiencing equipment damage from repeated loss of your neutral? For small loads, certain types of UPS will protect them against excessive voltage.
This is easy to detect; for example you can buy voltage-sensing relays that can be set to operate an output when the voltage goes out of range. These could then operate a shunt-tripping add-on unit to a main breaker, to isolate your panel from the faulty supply. On the more sophisticated ones you can set the thresholds and delay time to minimise nuisance trips on start-up surges etc.
I got to admit that you are pretty sharp on electrical, are you some sort of engineer.
Yes, although I've long since forgotten which sort!
Reply to Protection against open/loose neutral? in the UK Electrical Forum area at ElectriciansForums.net
Legends, need some advice. I am a 12v automotive electrician, but have had a side project building a concession trailer for my dad. We have an...
Hello. New member here. Electrical enthusiast. I am at a friend's house in the Bahamas and decided to look at the load center in the house, which...
I would like to get some information on what protection is on a multi meter when accidentally testing a live circuit while the meter is on the...
Hello, I have a hypothetical question (I'm an electrical engineer) to better understand RCBOs and how they are used in the USA. Let's say I would...
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
