Discuss Relationship between AC Watts generated and DV Volts in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
T
timskipper
Hi
I'm interested to know what the relationship is between the two scales on these graphs; AC Watts generated and DV Volts. This is the last two days output from our 20 panel 4kw installation.
Can anyone explain it in plain English? :)
I'm not sure what DV stands for - but presumably this is the DC voltage from the panels. There are two lines so I would assume you have two strings of panels.
The power output (AC Watt) would be the voltage of string 1 multiplied by the current of string 1 plus the voltage of string 2 multiplied by the current of string 2 adjusted for the efficiency of the inverter.
The inverter will adjust the voltage of the panels during the day to maximise the energy produced.
Reply to Relationship between AC Watts generated and DV Volts in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello Is it possible for solar panel monitoring to over state the actual power generated by the system? My friend’s 6.4kW system has generated...
Hi everyone. The owner of the business I work for along with myself have created a DIY inverter setup that is giving us some issues. We bought...
Hi all, total newbie to the forum. I sincerely hope that those in the know-how would be able to assist me. On my semi-detached house we have an...
I'm taking a look at the 120v wiring in an old travel trailer that I recently bought, and plan to live in full time soon. It has some quirks that...
We have this Swiss-made Dixi horizontal borer from 1957, very nice machine still with its original DC variable voltage drive. In those days there...
