Discuss Remodeling location of dryer 4 prong outlet in the Electrical Appliances Forum area at ElectriciansForums.net
Kitkat
Relocated dryer vent. Old work 4 prong dryer outlet no longer attached to drywall.
So I think I need to rewire dryer outlet to new work 4 prong receptacle.
Any suggestions as to the location?
I thought to attach a horizontal 2x4 under window and another horizontal 2x4 under the dryer vent.
Then nail a vertical 2x4 between those two horizontal 2x4's.
Then I would nail the new work 4 prong dryer outlet box on the left side of the new vertical 2x4.
I know I need to stable both wire 6 inches from the boxes.
Is my plan ok?
Any other pointers?
Kit
Is my plan ok?
Any other pointers?
Kit
It appears there are to many cables and not nearly enough stapling to make that more neater. The box for the dryer has to be 4 wire and the plug has to be higher than the dryer
Ok thanks for the feedback.
I will try adding the framing and add insulated staples every four inches or so to see if takes up the wire slack.
Fyi its a stacked dryer on top of washer.
Kit
Kit
Then install the dryer outlet and washing machine outlet beside the appliances. New code change you shouldn’t have to pull something out to disconnect it
Thanks for information.
The unit is in a tight closet type area.
Will see if i can punch through sidewall for outlets.
Can you suggest what to look for in a multi meter to test the four prong plug?
Kit
Kit
Yes you can go to Home Depot or Lowe’s and buy you a inexpensive meter that you can measure voltage with which is all you would need a meter. Good luck
Reply to Remodeling location of dryer 4 prong outlet in the Electrical Appliances Forum area at ElectriciansForums.net
I have a 3 prong 240v outlet for a dryer that reads 240v across both legs and 120 across the ground. When I turn the dryer on and have the multi...
I'm a DIY'er helping a friend connect a 220v dryer to a 50 amp RV outlet. The dryer has a Nema 10-30R plug and is in a shed about 4 feet from the...
I built a prototype Dog Dryer. Took a dryer element and pushed it into a vent pipe. Cut out vent pipe to access the two spade connectors on the...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
Hello all, I'm an amateur DIY home-owner that recently moved into an apartment for a 6-month military assignment and these maintenance workers...
