Discuss Removing someone else's isolation in the UK Electrical Forum area at ElectriciansForums.net
Universal padlock key
https://www.NoLinkingToThis/p/makita-ga4530r-720w-4-electric-angle-grinder-110v/2864k
A cable joint and some lashed up distribution board. Cables hanging in free air that sort of thing.
I would like to know if it's illegal for someone to remove my padlock without my consent
In my 'opinion'..... It's completely legal for someone to remove it as we have no authorisation in the eyes of the law to isolate anything. You have followed best practice and refer to non statutory guidance which we all work to. Should something happen a prosecution would be sought under the EAWR. If you have done everything you can to work to the regs then that's all you can do. I'd take lots and lots of photos if I were you.
what would it take to make the repair safe? Could you do it? Maybe suggest to the boss you could make good the repair and they could bill the persons who caused the damage?
In a domestic situation I would agree with you but as this is a commercial / industrial job I would suggest that it would depend on the company policy and who is deemed to be the dutyholder in the situation and what is expected of them.
Unfortunately while prosecutions can and probably will be sought by the HSE under the EAWR this cannot resusitate a person who has died or restore a full quality of life to someone who has been seriously injured if a major incident occurs
The OP makes no reference to the qualification status of his boss or manager when he is the one making the request to the OP to remove the isolation
Seen it all to often where an incident occurs and the manager feeds the operative to the wolves despite them being resposible for the policy or specific request
There is clearly an issue here with the temporary repairs the details of which the OP has chosen not to detail for whatever reason, so the only covering backside solution here IMO is to sign the job over to whoever will accept the responsibility for the ongoing work, re-energisation and safety of the circuit(s) in question with I would also note that this is done under duress / pressure from --- and the reasons why you think the work should not be re-energised have two copies so each party can sign and each party has a copy so if the dung hits the fan you are clear
Reply to Removing someone else's isolation in the UK Electrical Forum area at ElectriciansForums.net
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
Hi all -- full disclosure I am a 'DIY-er' but wanted to post here for greater visibility seeing as I certainly won't be doing this work myself...
4K
Hi, I am looking to convert a 2 way light into just control by single switch. I have searched and looked for similar questions here, and found a...
Hola! I’m in the process of renovating an apartment in Madrid. The consumer unit is fitted with an old 15amp ICP switch. I believe its function...
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
