Discuss Ring floodlight cctv junction box in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
I fitted one of the ring floodlight cameras to a 4" round junction box that I got from amazon around 8 months ago. Customer has phoned to say the bracket holding the junction box to the wall has snapped.
Amazon don't offer this box anymore. Has anyone else found a 4" round waterproof junction box that will work with the ring cameras?
Can't seem to find anything suitable
What IP rating are you looking for?
How about something like this?
The cam is fairly heavy. Not sure a plastic one would be suitable. I fitted one like this.
I thought it would be easy to find a 4" round metal waterproof JB... I was wrong.
use a galv. besa box and make an oversize plate (4" holesaw in some 2mm gallv. steel) to mount the fitting after drilling the plate to suit.
If the camera was mounted onto that box I'm not surprised the brackets failed.
Even more so if the box was mounted with the brackets on the sides as photo.
It needs a box with better fixings than that, ideally 4 internal fixings.
No wonder they don’t sell it anymore :rolleyes:
Without seeing it, a cheap fix might be to reuse existing but go internal fixings with penny washers and silicon. I think it would stay on the wall, but keeping the water out will be the trick.
I think this may be the only solution
Reply to Ring floodlight cctv junction box in the UK Electrical Forum area at ElectriciansForums.net
Hello. Just a lowly homeowner here who is beginning to panic after a major house renovation regarding relocation of the main supply cable to the...
Hi, I purchased a Time twin strand bell cable with a rating of 12-30V, 2A, low voltage, not for mains use. I wish to use this for installing our...
I'm currently refitting a bedroom which has 3 double sockets and a 13 amp FCU (for a wall mounted TV). On inspection the wiring is as shown in...
Hi guys, I plan on installing a ring floodlight onto the brick centered above my garage door. I have some pictured attached I marked in red where...
5K
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
