jensenjosht
- Reaction score
- 5
I was wondering if I could get some help on trying to electrically solve this idea I had. I was wondering what the best way would be to set the maximum voltage limit from a variable AC transformer so that it could never exceed a selectable predetermined voltage and if it did, would just force the output voltage down to the predetermined threshold.
The variable AC input would be a from a Lionel CW-80 transformer that would power a conventional train set. The idea was to have a system so that you could never drive the train at a voltage higher than what I would select to prevent the train from being driven too fast and having the train derail violently. This was going to be used at Christmas event in November where kids will be able to operate the train and where a system described above would be cool.
I’ve done some preliminary research in to using a Varriac, voltage sensing relay, and a op amp comparing circuit, but I felt slightly confused, conflicted and overwhelmed that I wanted to put the idea in front of more possibly experienced minds.
0-18v ac 60hz, 80w for electrical loads. I can post some manuals for the transformer.
