Discuss Smoke Alarm help in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
R
RyanCheetham
This is a strange fault i have never come across and i am thinking the answer is to just replace the whole unit. I recently converted the lights in my nans hallway from a pendant to 4 downlights. Being a bungalow it only had one mains smoke alarm in the hallway with the feed taken from the light. I JB'd the switch line and loop in loop outs and moved the smoke alarm 40mm to the left to align it better for asthetics. The alarm worked fine before but after it just goes off randomly and frequently. I have blown out the detector to blow all debris out and the alarm has a shade over 450mm either side of it before the downlights edge so i don't think that is the issue. Quite frankly i am stumped by this. Any one have any ideas?
Well, if it's got a sound permanent supply, you've cleaned it out, and there are no interconnections to other alarms, then it would appear that it's faulty.
The only other possible explanation if it's a wireless type, is that the new d/l's are causing interference in some way which is triggering it.
It is a stand alone unit hard wired into the lighting circuit. I had the same conclusion after checking all the mentioned possibilities and was hoping someone else may have an idea. It is a council house and she has taken the unit off its base for now. I may just fork out and put a new one up for her. Better safe than sorry
Fluorescent lighting on the same circuit can cause false alarms. If you actually ever read the instructions which I know none of us do it does actually says it shouldn't be installed on a circuit which has fluorescent lighting on it. Just an idea might be nothing to do with your problem though.
I will disconnect the flouro for a day and see if that has any effect on the alarm, one last attempt at a fix before replacing it. Thank you for your help
Aico are pretty well suppressed, never hear of any flouescent or other equipment interfering with them. But have seen the same fault where the earth cable had been connected into the interlink terminal instead of the earth terminal...so worth a check, other than that, time to replace.
I fit hundreds of aico alarms. If its a short beep every 5 mins its a low battery. If its going off randomly then it's gone faulty. Does happen but not very often. They are good units. If the indicator lights are round then it's optical (the better one) if they are oblong then it's ionisation
Also check the replacement date on the sticker on the main unit.
Reply to Smoke Alarm help in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi Guys, just before i call the sparks out, am i able to remove a smoke alarm and get it in a junction box in a bedroom? they are hardwired so it...
I know this has been brought up before but as a QS for a housing association ,i have been asked my opinion on interpretation of the regulations...
Not come across this before, so would like some help, please. I went to install smokes and heat alarm (to new Scottish regs) in a fairly modern...
Having a bit of a mare at the moment with a small 2 story HMO (6 single rooms with shared kitchen) which was fitted relatively recently (2016 or...
Hey all, Could do with some help. I had a company recommended to me who quoted me to do an EICR on my rental property. (£265). I thought this...
