Discuss Tapping sound behind outlet/wall when using toaster? in the UK Electrical Forum area at ElectriciansForums.net
There's a contradioction between your statement:
I move the toaster out of the room and the clicking remain for five minutes
and
They only click when the toaster is on. Otherwise, there is no noise at all
This is important. If you hear any clicks at all when the load is switched off, it's not arcing. It also doesn't sound like arcing.
The toaster has been changed, therefore it is not very likely that a GFCI is unsuccessfully trying to trip due to a fault in the toaster.
If the clicking starts soon after switching the toaster on and continues for a short while after it is switched off, I would think it's a run of cable that is pulled tight over or through some woodwork and as the cable heats up with the current flow, it expands and the resulting movement causes clicking. The tension returns it to its original position when the load is switched off. The toaster only runs for a short time so you never get to hear the clicking stop once the cable has reached a steady temperature and stopped expanding.
You could test it with a low load, of say 100 watts or less. The temperature rise would be so much lower that I would not expect to hear any noises. Any other load similar to the toaster should cause it to make the same noises. If the load is left switched on for a longer period, the clicking might stop once the cable temperature is stable, and perhaps restart due to cooling when the load is switched off. This would be fairly conclusive proof of my suggestion above.
The sound might even be made by a joint in the woodwork itself, very slightly warmed by the cable pressed against it. That might indicate excessive heating due to a bad connection or bunched up surplus cable.
Reply to Tapping sound behind outlet/wall when using toaster? in the UK Electrical Forum area at ElectriciansForums.net
Hi there, Just about to move into a house with 2 small kids and the wiring/electrics haven't been updated in years (hard to know as it's probate)...
Hello, Not an electrician and I currently live in an apartment building. Over the past few years I have been having abnormal problems with my...
Our family room is part of an addition built a few years ago. We had an issue with nuisance tripping on an AFCI and the electrician came and...
What is the oldest dimmer switch you have seen in use recently? When did you install your first dimmer? (Veteran sparks only) I ask because a...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
