Discuss transformers/dimmer in the Australia area at ElectriciansForums.net
Z
Zaffy
My dimmer switch servicing six 12volt MR16 went. Pushed it in and nothing happened, no click. Replaced it with new component. Stil did not work. Replaced the two transformers. Still does not work. Any advice/tips before I call in an electrician?
have you still got power to the switch? to be honest, this would involve live working and if you a. are not competent. b, don't have the correct test equipment, then call a spark .
A more competent friend tested the wires with a neon tester, he said they were live.
could be that the transformers and dimmer are incompatible.
​hope he's still live.
Why all the jokes?
Friend had a small srewdriver with light. Light lit up, hence the wire is live.
Am I missing something?
Telectrix. How can I tell if the transformer and dimmer are incompatible? I replaced the transformer with like for like, the dimmer component is not the same make but I was assured it was equivalent.
Maybe a neutral, maybe not enough voltage which a "neon" wont tell you, your friend could have killed himself. You are missing plenty of things. Call a electrician in or even post your location on here and maybe someone on here could come and have a PROPER look for you. Shouldn't take too long to resolve the issue.
to a competent sparks, a neon screwdriver is like a brain surgeon using a chain saw.
zaffy, what wattage is the dimmer, and what's the VA of the transformers?
Reply to transformers/dimmer in the Australia area at ElectriciansForums.net
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
I have the typical LED on Dimmer switch. All the lights flicker in my house are very inconsistent times. By let me clarify by saying all the...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
