Discuss Wago's , junction boxes and choc blocks whats best with downlighters in the Electrical Tools and Products area at ElectriciansForums.net
I havent used wagos before. I still use those crappy normal connector blocks. Wheres the cheapest place to get these wagos and are they any good compared to normal crappy connector blocks
you should have gone to elex they had them on special offer , if they are approved for use in air craft then they are ok for me , i shall be trying out the din rail mount ones when i do a CDU relocation , hardly ever use crimps or terminal block nowadays they are just a superb invention
has been mentioned on the forum that the ashley type screw JBs are no longer allowed for downlights. Why? the only reason i can see is that they are not fixed to a joist, but then, neither are wago boxes fixed. can't be because they're screw terms. because they are accessible. any body shed light in this?
can't remember. it was on a post somewhere. maybe the member who said it was thinking of accessibility. i can't see anything wrong with them.
Reply to Wago's , junction boxes and choc blocks whats best with downlighters in the Electrical Tools and Products area at ElectriciansForums.net
Hi all, I am about to fit a light fitting and wanted some advice whether I should just connect the light cables into the correct terminal blocks...
I collect old Electrical Fittings and I recently acquired this vintage Junction Box (photos attached). I've been trying to figure out how it would...
Hi, Hopefully I haven't made an error but I was speaking with another electrician and he said standard junction boxes with screw terminals can no...
Hi all, DIY'er here looking for a bit of advice so please go easy on me. In my dining room there is an existing single pendant and i would like...
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
