Discuss What is the best way to install a device that requires 110-240V fused at 3A? in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
I have an Outdoor Air Quality monitor that needs mounting to 110-240V with a 3A fuse. See Attachment for manufacturer installation guide.
Is it possible to simply add a 3A fuse into any old plug and just wire it to the device?
Looking forward to your replies.
  • enLink-Air-X-Installation-Guide-V0.2.pdf
Hi all,
Yes, providing the cable is 3 core and you connect all three Line, Neutral and CPC (Earth).
Would be better if it's a permanent installation that it is fed via a fuse connection unit instead of a standard socket outlet, but a standard plug into a standard socket outlet would be fine.
Only other thing to note is you need to put a loop in the cable as a "drip loop" so the water doesn't travel down the cable into the device, or plug.
Thanks, Julie, For the permanent installation I will get an electrician to mount it correctly. I just need to power the unit to set up the device through LoRaWAN at home before going on site.
Reply to What is the best way to install a device that requires 110-240V fused at 3A? in the UK Electrical Forum area at ElectriciansForums.net
Hello, I have a EV charger that is reporting over voltage and is unable to charge. the charger will operate up to 253V The solar inverter reports...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
Hello, I am hoping this is in the correct forum. To start, I acquired a film processing machine that runs on 3 phase. Now before getting the...
Thought this would be the best place to vent. As most of you know I work abroad. Australia. So during my long arduous Nightshift I got talking to...
B
Prefix - I've tried to post this in automotive, but it would not let me. This may be because I have not been recently active. Apologies if this is...
