Photo of the cupboard
Nought to do with your problem, and probably bottom of your list of things to do, did the electrician say anything about the Wylex mcb in an Eaton CU?
The switch labelled solar PV is for the solar PV, nearby you should find an instruction label that tells you how to turn off the solar PV, there should be a local isolator switch labelled AC isolator and another one labelled DC isolator (this may be in the loft or near your inverter), switch off the AC isolator and then the DC isolator, switch off the solar PV circuit breaker.
Oh and by the way
I just remembered I bought one of these because I thought it could measure dips and surges
It was a desperate attempt to find the problem
However I don't really know how to set it up
https://www.amazon.co.uk/gp/aw/d/B0...s_1?ie=UTF8&psc=1&refRID=RG88QZX70ATZHS2YYM23
These are simple meters that can tell you how much power you are using at the current time and how much power you have used over a period of time, however it will not indicate anything, at time or provide historical data, about the state of the power supply.
I can see the end switch says solar PV
I'm not sure about AC isolator or DC isolator. Is it that other box with the big red round thing in my pic
It is prolly best to wait until Monday when the electrician comes
Ah ok
No use then
Perhaps I will sell it
Mmmm I'm clueless what the heck does that all mean?
Anyway I will add it to my list to ask him when he comes on monday
Its a minor issue, but you not should mix different manufacturers products in a CU, unless they say they are compatible. Add it to the list.
Reactions: beachlover
It ok to test these theories
Theories they are indeed, and with or without theories or headscratching or doing nothing at all-you will still have a blown computer. So theories are not hurting or adding to your problems.
Power analysis is a way of establishing some facts. Maybe I am wrong fully accepted and I do offer this very tentatively, but at least you are out of the realm of theory and into facts. What would it hurt to try it, well apart from your bank balance. At least if you turn off the PV you should be able to find out if it is a contributive factor without power analysis.
Maybe your landlord would put something toward power quality analysis monitoring?
I think I would be looking into a Harmonics filter for single phase. The energenie power meter would in no wise give power quality analysis. A meter for this type of work costs upwards of £1500. There are companies that specialise in this. However it is not cheap. And finally it may not be the answer. I promise I wont talk about this again.
I have added it to the list to ask the electrician on Monday
I'm not sure who's taking the mick here now :-) Daz
Not too sure about the last one....MCB! first line
Square peg in a round hole. If Eaton say a Wylex mcb can be fitted in one of their CU's, then that's fine. I'll doubt they would.
Bit confused there Midwest no oblique reference to your correct I.D. of mixed MCBs' its just the beachlover wrote MBC instead of MCB in first line, the first part was in reference to the last point in Beachlovers' list of points to bring up
Nobody has asked what 'signal phase' is yet either. Daz
Apologies :)
Lol
I can't even blame the iPhone that time single phase
I scrubbing it out and writing a hundred lines
I must spell single I must spell single
There is the list so far
I'm hoping he doesn't think I'm some sort of smart Alec or a crazy dudess
Lol
Lol
Should I add anything else to the list ?
Perhaps I should ask him to PAT test the freezer we have in the shed?
It's the only appliance that is not new
. Brought it with me from the previous property. The property were computers did not blow up !!!
I'm not an electrician but I some clever heads together
beachlover,
beachlover,
