- Apr 29, 2010
- 1,695
- 420
- 101,758
Hi All
Hopefully a simple answer I can relay back to Client.
My TV engineer is away on hols at mo, so after bit of advice from others please
Have wired a new build property for SKY Q, fair size place so have hard wired as precaution and Client wants to go with hard wired set up throughout.
This is what we've done :
- Twin ct100 sky box to dish.
- Cat6 socket in each bedroom x4/ linked back to cat6 x4 socket behind SKY box .
- Also have Cat6 socket from behind SKY box which links to router in other room.
They've had Sky engineer out who didn't seem to have a clue ! Spoke to him and said only has x1 data outlet on sky box so can't wire up.
Am I correct in thinking they need something called a switch? The data cable coming out from SKY box goes into this which then splits and feeds the x4 cat6 sockets?
If so, is it just case plugging it all in and will work as hard wired or will it need setting from scratch?
Hope all that makes sense
Thanks very much
Sy
Thanks very much
Sy
