Discuss I need some help! ASAP, questions a put wire, three ways and stoves. in the UK Electrical Forum area at ElectriciansForums.net
This is the digram that i came up with, i am running mostly 12-2, on 20amp for everything. Except for my electric stove, i was planning 6 gauge wire on a 50a.
i am trying to wire in two three ways light switches, and was going to run 12-3 between them and 12-2 to the lights and the service panel. Does that work?
Yes that will work but you can use # 8 wire for your stove
Reply to I need some help! ASAP, questions a put wire, three ways and stoves. in the UK Electrical Forum area at ElectriciansForums.net
Hi, I've a 50A circuit (looks like 6 gauge wire - see image) that used to service an old hot tub and I want to convert it to 20A 12/2 to service a...
This weekend I was replacing a hall light fixture in my old home (rewired circa 1980/90's) and noticed the work was done using one of the exposed...
Hello. I am new to wiring and could use some help getting this circuit wired in the kitchen . I am trying to get the source power to the GFCI and...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
