A
Alex411
Hello,
1979 classic Mini neg earth, been updated from glass fuse to blade fuses in a side entry fuse box with a few extra ports for accessories.
Everything is working fine. BUT.
I want to hardwire in a USB port which should be simple but I can't seem to get any luck. (Like everything with a classic car it takes a few attempts)
Multimeter set to DC on 12v across the battery is getting a reading. On the fusebox though, no matter where I poke I can't get a reading with the ignition on or off (this is likely down to me being uneducated) (because everything works.) tried then putting the neg sensor on the bodywork and poking around still nothing.
Ignoring all the above I thought, just wire it up to a empty port, put in a 7.5Amp fuse, its across 17amp wire, jobs good. NO.
Wired it into a fuse port I know is working put the 7.5 in that one, still nothing.
I know it's a really simple job, so I know the issue im having is probably very obvious, but I'm trying to learn to avoid paying the auto electrician £80.
I hooked up LED lights all round which are working a treat, so thought this would be a doddle!
Any advice is much appreciated, thank you, and if this is the wrong place to post apologies I shall move it.
p.s the unconnected connection in the pic please ignore, I put that back.
Thanks,
Alex
Thanks,
Alex
