Jffy734
USA
United States of America
I have a 2-year-old GE dishwasher which several months ago began to not work. It turned on but soon shut off without starting the cleaning process. When this happened I went to the breaker box and flipped the dedicated switch for the dishwasher, waited a few seconds, then flipped it back. After doing this it usually solved the problem but now it doesn’t and even after flipping the breaker box switch the appliance still doesn’t work. Does this sound like more of a problem with the dishwasher or with my home’s electrical system? The home is 27 years old.
Thanks very much in advance for any feedback!
it may be a kink in the water feed or drain hose.
These machines are too clever nowadays, and will shut down/ not work if they dont get the expected water pressure, or are not able to drain the water away sufficiently.
To start with a dishwasher is required to be on a GFCI receptacle and a dedicated circuit. With that being said I think it’s possible that your electrical outlet that it’s plugged in is the problem. My advice is to contact an electrician.
Yes the dishwasher is on a dedicated GFCI receptacle and circuit.
Thank you and the other forum member who has replied!
Good luck
Reactions: Jffy734
USA
Any thoughts on 2-year-old GE dishwashing machine electrical issues?
USA Electrical Forum
Jffy734,
Megawatt,
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
