S
spark-ticus
Hoping the wealth of knowledge can shed some light on this..............Have fitted 6 sets of "cable track lights" each set consists of 2x 5m cables spanned parallel across the ceiling with 5x 35w fittings screwed to cable piercing the insulation to obtain L-N. Each set has a transformer with the following spec; PRI 230v - 240v ~ 50Hz SEC 12VAC ~ 17.5A 210VA
I have wired 2 sets to 1 swich in each case, but after i have turned the lights on and they light up beautifully i then turn them off and they trip the breaker (10A type B mcb). Any ideas on what is happening would be greatly appreciated......
